Hello all,
I would like to gain your views and opinions on how the Intel platform has changed you experience regarding CAD for better or for worse.
Example questions:
** These apply to any applications or packages you have used **
Have you stayed with one package, upgraded your Intel CPU and noticed a considerable change. From what CPU to what CPU?
Has upgrading the CPU made the biggest difference or have other hardware components made a difference?
Can you give examples of how the upgraded Intel CPU has made a difference to your CAD experience?
Is there anything you can only carry out well on the Intel platform?
Do you use CAD on other devices, e.g. tablets, mobile devices?
If you could give me as much insight into how the Intel platform helps aid CAD, I would be very grateful.
Thanks
Evoss
Example questions:
Thanks
Evoss
 10+ years.
