Experience with Waizwol?
25 Jul 2007
Essex
Asked a friend to grab me a Waizowl OGM Pro V2 from China, should be here on monday. I was wondering if anyone has any experience with them. Cheers.
Nope, but I have read only good things online, reviews rate it highly and the specs are top tier.
It reminds me slightly of a Lamzu Thorn.
I told myself that I would stick with a Zowie EC2-DW, and will do so but this mouse has me curious, seems expensive even from China though.
How much did you pay?
Very good mice. High build quality with no creaking, at least in the copy I had, and generally good switch implementation.
Around about £60 quid maybe a touch less.
Depending on the exhange rate, I think you can get it for around £70 or so if you manage to stack discounts Ali.
These “Chinese” mice, price wise are creeping up.
I am enjoying my EC2-DW, have been toying with trying a Lamzu Thorn again..
It’s like buying handbags at this point :cry:
My Cloud V2 turned up today - ordered on 13th.
Comparable in size & shape to my sensei 310 as I wanted. Feels lighter.
Nice that it came with no skates attached, you get three sets to pick from.
I attached the side gripe tapes from the set it came with as with my grip the sides were a little too smooth, but otherwise the coating is nice.
The scroll wheel is not quite as nice as I'd like - the feedback as I scroll is a bit more defined.
Downloaded the software & selected the Cloud - nada - its apparently a Cloud Hawkeye according to windows, so selected that. Updated the firmware on the dongle (2.02 vs 2.03) & mouse (1.0.5 vs 1.1). Note the mouse firmware has to be done with the cable attached. The dpi switch can have multiple presets to cycle through - default is 400/800/1600/3200/6400 - changed mine so 1200 was an option.
At 8k polling battery used 5% in 2 hours 30.
Battery sounds promising.
Quick update, got my OGM Pro V2 and I am quite happy with it so far. The clicks are great and the shape is comfortable. Debounce set to 2ms to avoid clicking when aggressively repositioning the mouse.
