- 14 Sep 2003
- Fareham, Hants
Im a fan of Lian-li cases. My main is i a v1000 plusII at present and Ive just snagged an original V1000Z for a nice price.
now I know that the plusII improved airflow by adding the side exhaust fan, does anyone have any experience with the original v1000? - does it need me to add an exhaust blow hole in the top/side of the case (ala v1000 plus), or are you running with OK temps?
Before I build into the new case I plan to cut some cable management and heatsink access holes in the mobo tray...BUT for those of you with a v1000, or with experience of one, if you had the chance to mod one before you built into it, what else would you consider?
