Experiment: Need Benchmark Gurus Advice
9 Dec 2006
@ManCave
Going to be doing a Experiment soon, quite an expensive Experiment i might add.
Need a few in Game benchmarks That are not held up by the CPU & that are very heavy on the GPU.
i was thinking of Sleeping Dogs Maybe TR?
But wanted your suggestions.
need to rule out the CPU as the bottleneck for this experiment (5930k)
Use Firestrike Ultra and use 8k in the custom settings.
Guaranteed to work any GPU to the limit and there is very little CPU involvement.
Timespy @8k is good too.
4K and just run for 60 seconds in game on the same scene (using fraps fps output txt) or as Kaapstad mentioned run 8K or 4K and check GPU score.
If it's a single GPU yes, if not your going to be CPU bottleneck to some point.
