- 6 Sep 2016
I understand dsl, you have a telephone connection box, you fit a dsl splitter for phone and dsl box output then connect rj45 to router and it works.
How is fibre connected from outside to in, what cable is used and what is the difference between boxes themselves and the spec requires for fibre optic.
And specific make and models where I can replace the dsl box with fibre box.
Do the boxes look different at the back panel ie is the cable unique and tell difference dsl and fibre box.
