explain push-pull fan setup please.
22 Nov 2009
Cornwall
hi,
this might sound like a stupid question too ask but i dont fully understand it.
i have just bought a corsair H50-1 and and people are saying you will get better temps if you use a a push-pull setup.
so how would i set up the fans? would it look like this;
--------> || <-------- , or this , -------> || -------> , or this , <--- || <---
|| < this is the H50-1 Rad, if you guys dont understand my diagrams.
or am i completely wronge on my setup?
I've heard mixed opinions on whether having the fans as intake or outtake works better for the H50, currently just still have the 1 fan on mine as intake and it seems okay.
Using the fans as intake will get lower cpu temps since it will be cold air from the outside blowing across but warmer temps for other components since hot air will be blowing into the case.
the way my current cpu cooler is position allows it to immediatly vent out of the case through an 120mm fan on the rear, this keeps temps rock bottom for me. i hope with my new bundle i can keep the same setup but because the Prolimatech Megahalems Performance CPU Cooler is a lot bigger than my previous cooler i might have to work round it.
