Hello everyone!
It's been a while.....
I would like to share this thing I've been working on recently. I have previously shared it with SFF community and it has been renamed to "dead space", generally disliked for being too big - not to standard basically
Explicity is a 22 litre enclosure with some design principles in mind. It's all aluminium, made in Stoke
So, what can fit inside
I am now browsing Overclockers for RTX4070 Super to utilise the space, can't afford the 4090 yet
***Sorry I thought I could link the images from my Google Drive. Will edit as soon as I can link photos***
- has to be thermally efficient
- has to be easy to build in - don't want to build the case around the components
- can't have a PCIe riser cable
- can't have a PSU extension cable
- be relatively small
- ITX motherboard
- SFX-L power supply
- 280mm AIO or 155mm tower air cooler
- RTX4090FE
.***Sorry I thought I could link the images from my Google Drive. Will edit as soon as I can link photos***
I've put mine in with a 1/2 ton arbor press and even a hefty C clamp and a broken wrist in a pinch. But then I'm using 1050A aluminium because I'm doing a lot of folding.
