21 May 2010 at 00:11 #1 clarkdevlin clarkdevlin Associate Joined 15 Mar 2004 Posts 123 Nod can't remove it, any advice?
21 May 2010 at 08:20 #2 Admiral Huddy Admiral Huddy Man of Honour Joined 17 Feb 2003 Posts 29,640 Location Chelmsford Download this : https://secure.avast.com/web/eng/avast-virus-cleaner.html boot into safe mode and run. This belongs in Windows forum
21 May 2010 at 21:39 #3 clarkdevlin clarkdevlin Associate OP Joined 15 Mar 2004 Posts 123 i tryed to download that software but it seems like a deadlink, know any other alternatives?
22 May 2010 at 00:33 #4 SiriusB SiriusB Soldato Joined 16 Dec 2005 Posts 14,443 Location Manchester Works fine. Try downloading it on a different computer. Some viruses can block websites for AVs and such. Could also try NOD32 [free 30 day trial], Avira, AVG etc.
22 May 2010 at 12:15 #5 theheyes theheyes Soldato Joined 17 Jan 2007 Posts 8,944 Location Manchester That's what I thought at first but you get 404 if you follow the link at the bottom of the page, try this instead I think it is the same thing: http://www.avast.com/free-antivirus-download
22 May 2010 at 21:06 #6 Draeger Draeger Soldato Joined 4 Feb 2004 Posts 13,474 Location Écosse Download SuperantiSpyware and MalwareBytes. Install both. Turn off your System Restore and reboot into Safe Mode. Run SAS. Then to be doubly sure, run MalwareBytes. That should do the trick. I have yet to come across a piece of spyware/malware that these two could not cleanse.
23 May 2010 at 00:44 #7 clarkdevlin clarkdevlin Associate OP Joined 15 Mar 2004 Posts 123 I've tried those out states nothing found but when i use nod that virus keeps poping up. This virus really that strong to remove?
23 May 2010 at 12:03 #8 Steve M Steve M Associate Joined 14 Dec 2007 Posts 1,586 Admiral Huddy said: Download this : https://secure.avast.com/web/eng/avast-virus-cleaner.html boot into safe mode and run. This belongs in Windows forum Click to expand... Link to download it doesn't work and lastest version was 2007!
24 May 2010 at 10:18 #9 Admiral Huddy Admiral Huddy Man of Honour Joined 17 Feb 2003 Posts 29,640 Location Chelmsford Oh - I have a copy if anyone needs it. It's just an .exe needs no install.
