Got a strange problem with Vista and Explorer.exe. I have searched google far and wide and cant seem to find anything like this issue.
Vista loads fine, desktop loads normally and all appears well until I try to run windows explorer, or the Control Panel, or Display Properties. (But I can run other applications OK, like Nvidia Control Panel for example)
I get the following error...
I only use my Vista rig for games so it's running the bare minimum services and apps. I didn't think I had disabled any crucial services, but I have gone through them and enabled everything that looked like it might cause the above error but no difference.
I have done a spyware and virus scan, nothing there.
run sfc /scannow from both the desktop, safe mode command prompt and the recovery console from the DVD, it does show some messages that it was not able to repair all errors. Perhaps Explorer.exe is corrupt? Can it be replaced?
The last changes I recall making before the problem was uninstalling ALzip and installing 7zip due a to a zip file not extracting correctly with ALzip.
Anyone got any ideas? I really don't fancy doing a reinstall at the moment...
Thanks
Thanks
Never heard of that one before. *scratches head*
