Export to CSV - Excel
7 Aug 2008
Hi,
I've currently got a Spreadsheet which uses a Macro to Export to CSV. I have been really lazy and done the code just by recording the macro.
I was just wondering what sort of code I need to allow it to automatically point to a specific directory when the Save As dialog pops up.
Cheers,
Tom
14 Mar 2007
Winchester
WORKBOOKNAME.saveas YOURDIRECTORY is the basic way to do it.
Just rereading your post of you are simply looking to change the default direcotry that pops up when you press saveas then you can change these in the excel options. No coding needed.
OP
7 Aug 2008
At the moment I have just got a bog standard:
Code:
Sub ExportToCSV()
Dim strFileName As String
strFileName = Application.GetSaveAsFilename(filefilter:="Comma Seperated Values (*.csv), *.csv")
If strFileName <> "False" Then
    ActiveWorkbook.SaveAs strFileName, xlCSV
End If
End Sub
7 Jul 2009
Wiltshire
Hi,
You can use the InitialFileName Property....
Code:
Sub ExportToCSV()
strFileName = Application.GetSaveAsFilename(InitialFileName:="C:\", filefilter:="Comma Seperated Values (*.csv), *.csv")
End If
End Sub
I've added it to the code you posted so you can see where to place it, then change the Path to whatever you require.
Regards
OP
7 Aug 2008
Hi,
Cheers for the reply, that works well! How would I go about giving the file a Default name when the Save As dialogue pops up?
Also, I have some fields I have defined names to which I then move to a separate sheet so I can export to a CSV. So for example C1 is named Test. However, when the row is deleted with that named cell on it, it won't automatically rename C1 to Test. How can I go about setting this so C1 is Test regardless of if the rows are deleted?
