Exporting HD with Adobe Premier
5 Jun 2007
For my uni project i have rendered around 45 seconds of 3ds max project work.
I have put them all together into premier 2.0 and added titles etc.
I am having problems exporting them into a file that i can open reliably.
I am using k-lite mega codec pack, and have a fair experiance with codecs and compression etc.
This is my first time using premier, its great, but i just cant get it exporting properly.
The video is 45 seconds long, and the resolution is 1280x1024 (the output from 3ds max).
Any help would be greatly appreciated, as im presenting this project to a group of professors in 2 days!!
Charlie
If you know about codecs and compression you should know that mega codec packs are junk. ;)
Premiere can export to all manner of formats, it would be helpful to know which one it is you're using.
Codec packs are awesome!! :D i rarely watch anything off my monitors (XBMC;))
Ive had some good luck with the x264 codec, ill keep playing with that!
