Anyone have any experience fitting an extending tv wall bracket into thermalite blocks ? I am wanting to hang a 32" Led TV on one in our kitchen of a new build, was thinking about using the Rigifix as they get great reviews for dot and dab plaster boarded walls. However are they suitable for thermalite block walls as the tv only weighs around 6kg, but the force will be a lot greater at the full 50cm extension will the blocks cope or should i use a resin fixing ? thanks
