- 7 Feb 2004
I'm just redecorating my bedroom and working out the best way to use headphones whilst watching TV.
I'm thinking of purchasing a twin 3.5mm wall plate socket such as this one to go behind the TV.
Then using a single 3.5mm wall plate either side of the bed to plug Headphones into.
Does this sound feasible and what would be the best cable to run between them both I was thinking Speaker Cable or 75 Ohm WF100?
I've realised doing it this way would mean having to put a 3.5mm male into the TV headphone socket and the other into the correct socket in the twin wall plate depending on what side of the bed I wanted to send the signal to.
Could I simply use a single 3.5mm plate behind the TV and connect this to 2 plates (1 at either side of the bed) by making a Y Lead?
Sorry if this sounds confusing I could draw a diagram if that helps.
