My Asus P5N-D Mobo supports PWM on 3 of it's 4 fan headers and I use the Asus Utilities; AI Suite & PC Probe II to monitor these, also SpeedFan. System cooling is as follows;
1st = 4 pin CPU = CPU (OCZ Vendetta CPU Cooler fitted)
2nd = 3 pin Chassis Fan 1 = MB Chipset/System (Fractal Design 60mm Silent Series Cooling Fan fitted)
3rd = 3 pin Chassis Fan 2 = RAM (OCZ XTC Cooler fitted)
4th = 3 pin PWR (Not PWM) = (Akasa AK-FN057 Apache Super Silent 120mm Fan fitted - Rear Exhaust)
I want to extend this with one of these http://www.overclockers.co.uk/showproduct.php?prodid=CB-031-AK&groupid=701&catid=48&subcat= This should allow me to connect another 2 PWM 4 pin fans so my mobo has PWM control over 5 fans. The 2 extra fans are a Front Intake (HDD Cooling) and Side Intake (GPU cooling). As I want to have control of all my system fans, this cable could negate the need to buy a fan controller to manage these additional fans.
Can anybody tell me if the mobo software, to monitor PWM fans connected, will recognise the extended mobo headers/2 extra fans this cable provides?
Will the software display all 5 fans so I can monitor and manage all the fans from there?
Thanks!
Thanks!
...but that's a story is for another forum
