Hi,
I would like some guidance on the feasibility of extending the FEP tubes on my Gigabyte GV-N98TXTREME W-6GD waterforce graphics card.
The graphics card has an optimized pump and the full coverage copper base on GPU/RAM/MOSFET deliver the most efficient water flow and cooling performance at a lower noise level, but the FEP tubes from the pump to the rad are too short for me to fit the rad where I would like in my case.
I have 2 of these graphics cards installed, in SLI, so I am thinking that I would be able to create loop by replacing the FEP tubes with longer tubing and also fitting a reservoir between the pump and rad.
I would really appreciate any advice.
Regards,
Neilnhi.
Regards,
Neilnhi.
