Downstairs I have a Virginmedia Hub 3. From there I run an ethernet cable to a TP Link ethernet switch/hub network splitter. One cable goes from here to my desktop. Another cable runs from there up through the wall to provide an ethernet connection in my spare room/office upstairs. In the room above that, my son uses wifi for his devices but the signal is weak - it comes from the Hub downstairs.
Can I boost the wifi by attaching a router to the ethernet cable in the room below his?
Is there a way to boost the wifi signal in this way (or another if that's not possible) using a simple setup? I've tried to find info online and when it goes to set up using the IP address etc I get lost due to tech ignorance!
Thanks very much
Thanks very much
I didn't find it too hard to set up
