- 4 Apr 2003
I’ve had a couple more quotes from other SEs since, one is now saying £1000.
What would be the disadvantage of going with this and amending the drawings to show the central pillar? That would be the only amendment really? Unless the SE suggests anything else?
I’m not fully against starting again as you suggest, but will that really help me if it’s just the central pillar that needs including/amending? A friend who gave me inspiration for this did his own drawings which were nowhere near the standard of mine, he simply employed the SE, got the steel sorted and it got built
Once the SE has done his work it’s then a case of getting full quotes from builders right? And sorting building control?
Can I apply for a lawful development certificate to prove that it’s permitted development just from the architects drawings? Or do they need the work of the SE first? Peerzy suggested I can get it prior to the SEs work in post #2.
You are asking structural engineers to design on a design that isn't cost effectively or practically buildable at the moment.
The one who turned you down is the best structural engineer you could have appointed.
The other at £1,400 was very realistic pricing as doing the architects work for them and allowing circa up to 2 days design time plus 1/2 day for dealing with project matters and liaising with you etc.
Structural engineering is a very precise discipline. Achieving chartered membership to the institute of structural engineers is a significant task.
Given the advice you have had from the 2 SEs, and the issue with your design I wouldn't recommend going for the lowest price, go with the best SE. At £1.4k the SE is factoring in your design and use of an arch tech rather than qualified architect so knows how much of a problem project this can become.
You will still need building regs and a certificate of completion issued. For this you need the design and structural work to be correct so it can be built correctly off plan.
Suggest you use JHAI as they are a good value independent building inspector and much quicker than council building control.
Applying for the certificate of lawful development under permissive rights is a separate matter to the SE / Design. Feel free to progress that independently and I suggest you do show an amended central pillar.
