Extension Cable
29 Dec 2007
Hereford
My Corsair HX 750 requires an extension cable to reach the CPU socket at the top of the MB in my full tower case. I am about to order a Seasonic 1000W. Does anyone know if the cables supplied with it will reach in a full tower? If not will the Corsair extension work.
I Believe the Corsair is made by Seasonic.
I don't believe the Corsair HX750w was ever built by Seasonic. The 650w and under were Seasonic built but 750w and over were CWT units and still are. If it's a ordinary extension cable that just plugs onto the end of the existing cable from the psu then it will fit any psu. Pinouts are all the same on extensions as all you are basically doing is copying the component end of the psu cable throughout it's length.
As for the 1000w Seasonic find a review on the unit and they usually include all cable lengths. Seasonics website should also have the info you need.
