Hi Just having extension done and build is done. Extension base is concrete and house is block and beam
There is a cavity hole between extension and house flooring. What is normal process for the cavity hole to be filled. It’s over air bricks so builder said they cant just fill it. They just put a “cavity cover” on it. Just basically a white looking sheet.
However flooring people saying they can’t screed over the cavity cover. Any thoughts or advice
