Extention to my 360 HD lead
i think you should be able to get any other componant cable (standard one) and then use three connectors (available from electronics shops) to join the two cables together though you will probably lose a little quality, so go for a decent quality second cable.
i did look for a straight extension cable but it doesn't look like they are a common thing.
hope that helps
andrew
NokkonWud said:
For my setup not one of the cables are long enough when I use it upstairs, seems daft to me. Shame really.
Blimey how long do you want it?
You must have good eye sight if your screen
is upstairs and your 360 downstairs :p
Sorry couldnt stop myself LOL
Andy
