External DVD Drive MacBook Pro
I would imagine that there should be no problems, you could check the manufacturers website to see if you need any drivers.
I know from experience that Lacie drives tend to just be plug and play on a Mac, although they are typically firewire based.
Is the Mac Air's external DVD drive compatible? If so I would get that - guy at work was using one the other day and they look and perform well.
