She's given me the okay. She is amazing. I love her to bits (yes she'll see this topic).
Not sure if this is best here or I'm home and garden.
I have a drill I hired for doing the tumble dryer vent and whilst I still have it makes sense too use it
Need to lay 4 ethernet cables to my garage from the routers location. Tried wifi and home plugs I want a gig LAN setup.
Homebase have offers on garden hosepipe. 50m is £20.
I have 2 boxes of cable already, I will just double this up.
I was thinking of drill a hole though the wall and using an IP rated small box with the back sealed with silocen as means of entry. Outside from the box to the ground some conduit tubing so it looks smart. The hose pipe can run up the inside of this making it all water tight.
This has kinda been done already by the builders of this new house for the power to the garage.
Inside the garage I will just have the cable run out the wall as a naked bunch to the other end where I new them.
The house I was thinking of a terminated face plate. Looks neater then as to having a run of cables coming out the wall.
Plan to pull a length of cable the route I want to go so
I can get the right amount of hose. Then pull lengths of cable so I can enough in the garage. I could terminate that into a box or just rj45 ends. Will see.
4 cables is for bandwidth and redundancy. Been caugh out before.
Anyone any ideas or am I about right?
