External Exhaust Fan by PCIe Slots
18 Oct 2002
Devon
I'm thinking of mounting a 92mm fan externally as an exhaust for my GPU. This will fit quite nicely in the recess in my case (Fractal R6) that houses the PCIe slots and I plan on fitting a cover on the back of the fan to stop anything hitting the blades. I have 2 x 140mm intakes one pointing at the CPU cooler (NHD-15) and one pointing at the GPU, I have the regular exhaust fitted to the rear of the CPU cooler so there is a straight through flow of air and this seems to work well, so was thinking that trying to achieve something similar with the GPU might be worthwhile, although the 3 GPU cooler fans will be swirling air in all directions which may effect things. I was just wandering if anyone had tried this before and whether the results were worthwhile. I guess I am trying to achieve better GPU cooling to allow the card to boost slightly higher and slightly reduce GPU fan noise.
You could try removing the remaining PCI covers to help the heated air be pushed out of the back of the case.
Seen this mentioned a few times, but can't remember who came up with it.
Whoever it was seemed very knowledgeable about this type of stuff though.
Thanks that's good advice and I forgot to mention that I have already done this.
If you have a spare fan why not try it and monitor your thermals, that's really the only way to know in your specific usecase.
I don't have a spare 92mm fan which is why I was asking if anyone had tried it but I've ordered one now so will post the results after testing.
You can still get a pcie exhaust fan probablly sound like a jet engine but it's an option and a blast from the past. :D
I've done this before. It absolutely does help when you want to run things as quietly as possible and the airflow for your case is naturally a bit unhelpful (I had the Corsair 650D).
So for example, I eventually modded my instance so I had the 200mm fan (at the front of the case) directed towards the GPU and a 92mm fan in the PCI Slats helping pull the cool air across so the GPU fans could get more cool air rather than have lots of warm air build up and then cause difficulty with the cool air trying to reach it (as the warm air being generated is trapped there for longer). If you have a lot of airflow already this may or may not be as helpful (depends on case design).
This allowed me to run things more slowly and also keep the GPU at a more controlled level. Whilst if I didn't have it, the fans would have needed to be set at a higher base rate that would have been audible. So there's definite improvements to be had in GPU temps, but how much improvement also depends on other factors. (Cooler design, temp targets, noise levels, etc)
:: edit ::
Here's an older image of what I did, but same principle:
Oh, before anyone gets on my back. Yes, that top front fan IS in the right orientation. :)
And yes, that IS blu-tac on the case in blobs. It was used to dampen the side panel from vibrating too much and echoing out noise generated inside to the outside.. As well as to hold boxes that have been fashioned into ducts to direct air going in and out of the case on the outside, and added foam inside to help dampen the noise that echoes out from all venting points.
So I have the fan fitted, I used black duct tape, and I'm quite pleased with the result.
I tested the setup before fitting the fan by running 3DMarks Stress Test and logging the sensors with HWInfo,
Av CPU 54c
Av GPU 73c
Av GPU Hotspot 95c
Then I did the same after fitting the fan (Av RPM 1450)
Av CPU 53c
Av GPU 73c
Av GPU Hotspot 95c
So at best I saw 1c drop on the CPU presumably by getting ride of some warm air before it could make it up to the top of the case.
I then upped the fan speeds across the board.
Av CPU 52c
Av GPU 72c
Av GPU Hotspot 93c
So looking a bit better but needs some more tweaking.
Next step is to install Asus FanXpert so I can manually tweak the fans on the fly rather than having to go into BIOS each time.
Overall though I'm slightly disappointed that it's not made the immediate noticeable difference I was hoping it would.
Hmmm, you've really only got about 1/2 of your fan there working the extraction airflow side (after ther permanent parts of the PCI slot covers block the airflow). As your GPU heatsink fins are vertical and not horizontal, so it's not grabbing as much of the heated air out from the top few slots used by the GPU.
Looking at the case, it looks like there might not be enough airflow overall to keep any beastly units cool through air only with just the two front 140mm fans. Not without making them noisey at least, which appears to be what you are attempting to avoid doing. Are you testing with the cover (over the vents) on or off?
After further testing I think my existing cooling was working pretty optimally before I started and the addition of the fan at the PCIE slots made little difference. I suspect this is largely due to having the blanking plates removed and a 140mm intake fan pushing cool air through the case, supplying the GPU fans and pushing warm air out of the unobstructed back. Heat from the back of the graphics card is being rapidly pushed out by the CPU cooler airflow. So it was an interesting experiment but one that I expect will vary from rig to rig so may still be worth trying if you have the time and inclination.
Did you try the fan as intake ?
Nope once I established that the graphics card really didn't benefit from additional airflow I stopped experimenting and just set the lower intake and exhaust to about 600rpm so they are silent but providing a decent through flow of air.
Having the lower fans maxed out made no difference to the GPU but the CPU benefitted by a couple of degrees I'm guessing that the extra turbulence from below diluted the hot air from the back of the GPU but as the CPU is undervolted and has a negative PBO curve it runs cool enough anyhow.
Sometimes the easiest way is to simply buy a new case. Some Lancool 215 B Grade or Lancool II Mesh B Grade can do what many extra fans won’t.
I'm very happy with the Define R6, I chose it because of the aesthetics and it's sound dampening. Given my priority for quiet operation I knew there was always going to be a compromise over cooling ability vs airflow orientated cases. The case does have the option to remove the front door and top panel to improve cooling efficiency but at the costs of looks and increased noise which isn't what I want.
Thing about noise suppressing cases is they often then restrict airflow leading to higher fan speeds. I run a bequiet Pure Base 600 with water-cooling, and with 480mm radiator space it's unreasonably warm (44° liquid temps). There's a whole argument going for mega air flow cases and low fan speeds.
Fans, speeds, noise, and temperature is such a complex multidimensional issue and it seems every individual build needs experimenting to get the best results.
Very true, however things have changed from the good old days of chasing usable performance gains through throwing more volts at components with the resulting additional heat being generated and additional cooling requirements. We now have CPUs and GPUs that can be undervolted to reduce their power draw -> operating temperature -> cooling requirements whilst still providing sufficiently high performance that you wouldn't notice any difference from operating at stock.
The new Lian Li 216 case has a bracket for this (although you need to supply your own fan).
Some of the reviewers tried it with and without the fan and it didn't seem make a huge difference. I think the orientation of the heatsink fins on the GPU allowing air to exhaust out the back has some effect. Unfortunately I think your heatsink has fins running perpendicular to the pci-e port (if that makes sense) so the fan won't be as useful as it perhaps could be.
