External flash setup advice
5 Oct 2004
Notts
I'm looking to start using multiple flashes on some jobs so would like recommendations and advice on what to go for.
I've currently got a Canon 430EXii and never felt I needed to upgrade to a 580etc. However I now need to look at my options. Should I get a 580 and use the 430 as a second with the inbuilt trigger or go for something like a pocketwizard and keep the 430 as the master and buy a 3rd party second flash.
Any help would be great :)
600ex-rt, it's cheaper than getting Pocket wizards or about the same.
You could get the. Yougoun but I've not had good experiences with them on terms of recycle time.
I read that the 600ex-rt uses a different tranmitter method so not compatible with the 430EXii?
I've seen a full PW setup 2nd hand for £200 so though that could be a winner?
