Hi all, not sure if this is in the correct category but here goes.
Basically my computer will eventually be put on a shelf which will give me a lot more room (I only have a small room). The shelf is quite high and due to the layout of my room my desk will need to go directly underneath the shelf, this means that I would struggle to reach the power button and USB on the case unless I stand on my bed.
Is there a external front panel available that I could mount to the underside of my desk? Or is it a case of having to buy a button myself and do some soldiering, in any case I will probably be needing a 2 meter plus extension so that I can cable manage properly.
Thanks for any help
Thanks for any help
