Id like to put 2 lights either side of my garage (the ones that shine up and down so need to be mounted in the middle of the wall) on the brick pillars but Id also like to conceal the cables and not use conduit. The pillars I assume are block inners with brick on the outside so I was wondering what the options are for the cables?
I'm not keen on drilling right the way through as it may affect the structure but could I remove the motar to run the cables and then re-motar afterwards? I notice you can buy ready-mix motar, will that be ok to use?
Not my house but its similar garage set up to the below
![](http:////i.imgur.com/XKmZHe5.png)
