External monitor with an Alienware 18
11 Apr 2004
Can I connect a 120hz monitor to an Alienware 18 and get full 120hz using a mini display port to display port cable?
Also can you tell me what happens when i plug an external monitor in, does it disable the the monitor on the 18? As Ill just want a single monitor running when using an external one as i'll have the 18 on the floor, out of my view range.
