Hi,
I have a desktop PC with four USB 2.0 ports at the rear and would like to add more USB ports - extra 4 ports should be fine.
What would be the better option -
(1) External hub (with psu)?, or
(2) Internal bay hub?
- what sort of connections does this have?
- does it connect to the motherboard or to one of the external USB ports?
- are there any links showing the installation instructions?
Any major advantages/disadvantages between the options?
Thanks
Thanks
