External Power Pack
15 Jan 2003
South East
I've just had back a warranty replacement for a faulty 3Com gigabit switch.
While waiting for the replacement I bought another 3Com gigabit switch. Both appear to be identical though they have different model numbers and the power packs are rated slightly different.
My original switch has 12V DC / 1.25A Max stamped on the metal plate and the external power pack reads: Input: 200-240V - 50/60Hz 0.4A and Output: +12V - 1.25A.
My new switch has 12V DC / 1.00A Max stamped on the metal plate and the external power pack reads: Input: 100-240V - 50/60Hz 0.5A and Output: +12V - 1.00A.
My question is, is it ok to use the new switch's power pack with the older original switch?? One reason I ask is that the older power pack seemed to be quite warm compared to the newer power pack.
Anybody?
I've also discovered that the damn power pack for the original switch is dead (probably the real fault in the first place unless it also damaged the switch through it failing).
One more bump. I'm going to have to call 3Com on Monday and get another power adaptor anyway.
