Permabanned
- 10 May 2004
- Preston,Lancs
Hi All,
Not really sure where to post this as it could have gone in a few places but you sff chaps are prolly best bet
I have a Soltek Qbic sff with a laughable 100W seasonic PSU. now the fact that this little PSU has been running a XP2700+,512MB DDR, 2 x HDD , 1 X DRD R/W and a 6800le ( unlocked to 16/6 ) is amazing but I feel the need for more juice. I've found what appears to be a nice tidy little PSU and what I'd like to do is bolt it under my desk and run the molex cables to my HDD and DVD drive thus unburdening the seasonic so it can concentrate on cpu,ram,mobo,gfx
This is the PSU I have in mind
Enhance ENP-2120A 200W
Specification
P/N: ENP-2120A
SFX12V Rev. 2.2 & SFX Backward Compliant
High Efficiency
Remote On/Off
Power good TTL Signal
Short Circuit, Over Current & Voltage Protection
IAPC, Wake-On-LAN Technology Ready
Auto-Sensing Thermal Control
Low Acoustic Noise
Output Wattage: 200W
AC Input: 100 ~ [email protected]/60Hz or 200~[email protected]/50Hz; Manual Select
DC Output: 3.3V+5V combined load 130W; 3.3V+5V+12V combined load 190W
MTBF: 100,000 HRS
Safety Approvals: UL/CUL, CB, TUV
EMC Regulations: FCC, CE
Cooling Fan: 12V DC, 80 x 80 x 20 mm
Dimension(WxLxH): 3.9 x 4.9 x 3.0 inch / 100 x 125 x 76.5 mm
Connector:
This power unit has: (1) ATX 20 Pin connector, (1) ATX12V connector, (4) peripheral power connector, (1) floppy drive connector
How can I get this to kick in at the same time as the seasonic once I boot my system, obviously it'll require pins shorting or a connection to the mobo but from that point on I'm goosed if I know how to do it and wondered if anyone has done anything similar and can give me a few pointers.
all assistance appreciated
Kieron
Specification
P/N: ENP-2120A
High Efficiency
Remote On/Off
Low Acoustic Noise
MTBF: 100,000 HRS
Connector:
Kieron
