So I've been toying with the idea of using an external rad setup, which will be positioned on my my window bay. Unlike the conventional way using the MO-RA 420, I'm going to be using a Liquid Haus stand, that can support a twin or triple rad setup (with some basic modding).
I ideally want to keep it as cheap as possible, so will be using some exisiting 360 rads. Currently I have the V1 011d XL, along with the EK distro plate using the D5 pump and two 360 rads for the cpu (currently the 5900x) and the GFX (Red Devil 6950xt with EK block).
My questions are;
My questions are;
- as I'll be running the rads externally, I'll be using 6 fans in push. I was thinking of using the powered splitty 9 to hook up the fans, and then run SATA power cables daisy chained back to the case. I'm assuming the SATA Power can do this (run length will be approx 1.2 - 1.5m)
- For now, I plan on using the distro plate as the res/pump combo, though in the future I'd like to upgrade and get a pump/res combo for the external setup when funds allow. What is the best way to do this for power? I'm assuming that I can do just the same with the above and get 60cm SATA power extensons?
- Given that i'm using the D5 pump, will the D5 pump be ok to run an external set up like this? I'll be using Koolance QD3 disconnects (2 female/2 male).
- Finally, I'm going to be likely moving to either a 14700k or 7900x3d - would I still be ok with decent temps with 2 x 360 rads, and low fan noise, or would I be better off getting a 240 or another 360?
