Caporegime
- 20 Oct 2002
- Wish i was in a Ramen Shop Counter
I have this 32G SD card, not showing up in Explorer.
However, it shows up in Disk Management. It also shows up in my Mac OS.
(ps it is a Macbook, but another SD card shows up fine in explorer)
Things I've tried
1 - Different USB ports
2 - Putting the MicroSD card into the USB Hub's micro SD port
3 - Putting Micro SD card into adaptor (SD card size) into SD card port in the USB hub
4 - Different SD card in the same USB hub shows up
5 - The 32G card shows up fine in the iMac
6 - Mini Partition shows no corruption on the card.
I took a screenshot to show that on the left is Explorer and right is Disk Manager, what could be causing this?
Things I've tried
