External sound instead?
10 Nov 2006
Lincolnshire
After just purchasing my SB Z I'm thinking of getting rid of it, the reason being I need the space between my GPU's for cooling reasons.
Until I looked today I didn't realise you can get external USB sound cards so to speak, what do I need so I don't loose any quality for gaming and music from what my SB Z gives me.
I'll be using my old HD555's, do these external thingy's just use USB and you plug your headphones straight into them?
Up to £100.
No space above your top graphics card? I used that PCIe x1 for ages without any trouble, though I did have to move it down to the bottom PCIex4 when I rebuilt as the CPU cooler encroached too much.
I'm considering the same Born, I have the Z97 Gaming 7 board and on that I do have a 1x PCIe slot above the first 16x slot that I have my top gpu in but it's very close and with the gpu getting very hot I'm a bit worried about cooking any sound card I put in there!
From a sound quality perspective (speaker and headphone) how would a Xonar U7 compare to a Xonar Phoebus as they are pretty much the same price?
the u7 is pretty good what is odd is the choice in DAC chip
by all standards it's a chip used it highend home theater equipment so it's not well documented as a DAC for headphone use but then the u7 is designed for multimedia.
It does a good job for the money a bit like the d2x if I'm honest it will fair better than a d2x with headphones though.
there is a U5 coming out very soon.
Talking about external sound cards, you going to be selling the Sound Blaster X7 when it becomes available (December I think)?
It looks to be an absolute beast, it's like an STX/ZxR with a 100W speaker power amp added on - it's even got a headphone stand you plug into the back :D
http://www.soundblaster.com/x7/#home
Yep, it's the circuitry around the DAC chip that defines the sound not the chip itself. I think if it were possible to compare the outputs of the discreet DAC chips they would all be pretty close.
What I was trying to convey was that just because it's in a Creative Labs Sound Blaster box, it doesn't have to be a cheap and cheerful part. Obviously, they don't have the support circuitry and components that the high end DACs do although I do think in a lot of cases those high end DACs are grossly overpriced.
