Hi guys!
Should be getting my Antec P180 in the next 2days.
And I've always wanted to water cool a comp so its about time,
I don't really want to try to squeeze it into the case, so i thought why not make an external box
First i was thinking make it from wood, and then why not perspex
I've got part wise so far -
Swiftech Storm CPU block
Swiftech MCW30 Chipset Block
Laing DDC-12v with a prexi top
All picked up for a bargin in MM.
So heres the layout so far.
The Dimentions will be: 540mm x 205mm x 205mm
I'll throw some more drawing when i do them,
I'm hoping to use these drawings with a CAD machine at work.
I know the pipes won't go at that angle, but does that seem right to people for the way the flow should go?
cheers
Warren
cheers
Warren
