External Water cooling Boxes.
I'm currently in the process of making one. Brought some premium pine from B&Q and cut that to size. Had a nightmare trying to locate a hole saw to cut the relavent holes for 120mm fans. Got one arriving tomorrow so should be able to cut the holes, varnish, and then add the WC components.
I was thinking about wood, but have decided on persex :)
I'll be starting mine over the weekend.
I'll post up some of the CAD pictures I've got later.
gt_junkie said:
Gonna be so cool. Can't wait to see the build log!
Always been too scared of water cooling to give it a go! :( :p
gt
The problem with water is that it gets a bit addictive. You start off with a simple beginners kit and a few weeks down the line you've swapped half the bits out for better variants, wider bore tubing, etc, etc :D
That sounds painfully familiar!!! :( :p :D
gt
