External water cooling loop 1m 40cm high
29 Nov 2009
Would this work ?
I am looking at building a water cooling loop that is 1m 40cm at it's highest point & about 4m long
This is what I am looking at building
The pump,reservoir & radiator will be mounted on a cold solid stone wall, not inside the computer case
The only part of the water cooling system to be inside the case will be the CPU & GPU blocks & tubing to join them together.
Solid copper piping would be used to plumb the parts outside of the computer together.
Parts
Radiator - Konvekt-o-Matic MAXI Passive Radiator
With Konvektor Blower
Reservoir - EK Water Blocks EK-Multioption RES 400 Rev. 2
http://www.overclockers.co.uk/showproduct.php?prodid=WC-041-EK&groupid=962&catid=1551&subcat=
The reservoir would be mounted by the side of the radiator with the pump placed near the floor.
Highest point of 1m 40cm would be the top of the radiator.
The pump I am looking at is the - innovatek HPPS i-HighPower 12V Pump
http://www.overclockers.co.uk/showproduct.php?prodid=WC-000-IT&groupid=962&catid=1522&subcat=
Does anyone know if this is a noisy pump, I could build a wooden box to place it in to dampen any sound, with vent holes to let it breath.
I am looking at cooling my CPU Intel Core i7 920 not overclocked but well can be when needed & GPU 285
So is there any reason why it can't work & is using the copper piping going to mess anything up.
I chose that Radiator as its going to be at eye level so I need something the looks nice & a fan that's not going to blow air in my face.
Thanks for any help that you experts can give me.
