New system build :-
Fractal Design R3 Case
I5 or I7 with a Bequiet CPU Cooler
Gainward 580 GTX
The case comes with 2x120mm fans one at the front and one at the rear. Will that be enough to keep the components cool and allow for CPU OC?
Should I add a 140mm and if so should I add one at the top or one the side over the GPU?
I want to keep the syetm as quite as possible.
Gainward 580 GTX
