- 27 Mar 2014
- Newcastle Upon Tyne
Hi guys,
I've just recently purchased my new parts and completely built my system. At the minute its running with one stick of RAM because one is faulty and they are going back to be replaced. Anyways.... on to my question..
Currently on the MSI Z97 mini itx board there is only 2 fan connectors. 1 x SYS FAN and 1x CPU fan by the cpu block. At the minute I have a Cool Master Nepton 240MM AIO installed and that is connected to the SYS FAN by the spliter supplied with the kit. However the Cosair 250D comes with a 120mm fan installed in the front of the case which I can't connect because the CPU block is currently running off the CPU Fan connector. The case also has 2x 80mm fan mounts at the back of the case.
I want to definitely connect up the front fan as a intake but I'm lacking the connection points. Would I be correct in saying I can buy another fan splitter and connect the CPU block to the splitter and the case fan and both would run perfectly fine? Or can only the CPU fan be connected to that?
If so can anyone recommend a product to suit my needs? Preferably all black cables to match my others
Sorry for the noob question, its been a long long time since I built a PC.
