Extra GPU Cooling
9 Oct 2008
Somerset, UK
Hi i currently have a Sapphire 4870 and the fan is sort of annoying. Main reason i am using a Antec P182 with Noctua fans there great but when i am playing games my GPU fan is really annoying me. I cant use the bracket on the P182 to add extra GPU cooling since the 4870 is too long. Just wondered if there are any other quite options?
BTW this is the non references board so i cant watercool it.
any chance you can reduce the fan speed or does that cause it to get too hot ?
depending on the case layout any chance you could hang a 120mm fan in the case and direct it at the gfx card ?
Arctic Cooling Accelero Twin Turbo would be worth while as per Raikiri.
I'm real interested in the Accelero Twin Turbo and see it is supports the 4890. Anyone have one of these fitted and whats your opinion on temps and noise?
