Extracting data from HDD
27 Sep 2004
I have an old custom built tower system from a few years back. Unfortunately it died and wouldn't output any visuals, the hard drive still ran though. Possibly graphics card related but I needed an upgrade anyway so abandoned it.
I'm chucking the case and want to extract data(old photos, music, work etc) from the hard drive.
Is this possible without putting the hard drive in a complete system? It would need a power supply I imagine? Something USB related would be ideal.
Cheers :)
I have a device like the Slayer UK is suggesting, you add a HD in and it converts it to usb, got it reasonably cheap via auction, best solution I can think of
i have an external drive in a enclosure as storage which i take apart and swap drives had this problem when i wanted to recover lost data from a broken which connects either buy usb or firewire icybox enclosure but anyexternal enclosure you should be able to split and do the same thing with tbh
Actually the device I have isnt an enclosure XD - its like a plug and play sorta deal, it plugs into the hdd interface and is powered by a sata device then has a micro usb to usb so you can connect it to a pc
