So I'm having a woodburner fitted soon in my lounge, it will sit inside our existing fireplace. Now what I want to do is extract hot air from the fireplace through a 9.5" brick wall into the kitchen (see diagram below) with either 4 or 5" metal ducting.
So I'm thinking I'd need to insulate the ducting to keep the heat in.
The thing is I'm not sure how hot the air is going to be that is coming through the ducting.
Do you think this is viable ?
Would I need a special fan that can handle high temps, any suggestions, the fan only need to run at a low speed ?
Ideally I'd like the fan to be able to fit in the 6" gap between floor and bottom of kitchen unit and be fairly quiet.
measurements are approximate.
https://i.imgur.com/CWeZXBJ.jpg
