** Extreme Cooling Performance - XSPC Raystorm Kits **
  • Thread starter Thread starter rjk
  • Start date Start date
rjk
rjk
Caporegime
8 Aug 2007
Hi Guys
As usual, OcUK is the FIRST to bring you exciting new products from the watercooling giants that are XSPC.
With a range of products increasing in size almost weekly, XSPC are about the most exciting thing in watercooling at the moment.
The guys at XSPC have compiled some serious hardware into these kits
The Raystorm block is the highest performing CPU block on the market to date and offers superb flow rate along with epic cooling capabilities and a unique aesthetic.
The kits include the stylish, high performance D5 Bay res. This brilliantly finished reservoir mounts in the front of your case and comes complete with the most capable watercooling pump on the planet as standard.
With a choice of EX radiators for people wanting performance in a smaller package or RX radiators for those who want extreme performance, every possibility is catered for.
High quality tubing, stylish and secure compression fittings and performance fans complete the kit as well as all of the necessary mounting hardware and other accessories to incorporate these excellent watercooling kits into your system.
With the ability to include a GPU into the 360 kits easily, a completely watercooled PC is easily achievable.
Just add a coolant from our huge range of colours and you are good to go!
Stock is due in around 10-14 days or so, pre order yours now!
Check out the range below:
XSPC RayStorm D5 EX240 WaterCooling Kit @ £239.99 inc VAT
Kit Contents:
- RayStorm Intel CPU Waterblock
- D5 Dual Bay Reservoir
- D5 Vario Pump
- EX240 Dual Radiator
- G1/4? to 7/16? Compression Fittings x6
- XSPC 1650rpm 120mm Fan x2
- 120mm Fan Grill (Black Chrome) x2
- Intel and AMD RayStorm Brackets
- Socket 775, 1366 and 1155/1154 Backplates
- Socket AM2 and AM3 mounting kit
- 80mm to 120mm Radiator brackets
- 3mm Twin Blue LED with 4Pin Molex
- 5mm Blue LED with 4Pin Molex
- 2 Meters of Clear 7/16? Hose
- 24pin ATX Bridge Tool
- K2 Thermal Paste
Supports
AMD Sockets 939, 754, 940, AM2, AM3
Intel Sockets LGA1366, LGA1156, LGA1155, LGA775, 603, 604, LGA2011
*Requires mounting holes
Designed for multi-core CPUs
Only £239.99 inc VAT.
ORDER NOW
XSPC RayStorm D5 EX360 WaterCooling Kit @ £254.99 inc VAT
Kit Contents:
- D5 Vario Pump
- EX360 Dual Radiator
- XSPC 1650rpm 120mm Fan x3
- K2 Thermal Paste
Supports:
Only £254.99 inc VAT.
ORDER NOW
XSPC RayStorm D5 RX240 WaterCooling Kit @ £264.98 inc VAT
Kit Contents:
- D5 Vario Pump
- RX240 Dual Radiator
- K2 Thermal Paste
Supports:
Only £264.98 inc VAT.
ORDER NOW
XSPC RayStorm D5 RX360 WaterCooling Kit @ £289.68 inc VAT
Kit Contents:
- D5 Vario Pump
- RX360 Dual Radiator
- 120mm Fan Grill (Black Chrome) x3
- K2 Thermal Paste
Supports
Only £289.68 inc VAT.
ORDER NOW
Nice! The raystorm is a brilliant block, even edging past the ek supreme HF in both performance and looks. Yet to use my rx120 but from what I understand they are some of the best rads on the market.
without a doubt. these kits look expensive but in honesty, you really cant buy much better unless you start spending silly money on things like bitspower fittings etc.
the RX rads are simply fantastic and amongst the very best on the market.
XSPC is really hitting the market hard at the moment with some truly game changing products imo.
Indeed :)
Have you had the pleasure of testing out one of the full copper raystorm blocks yet? They are nice but twice the price!
@ pgi947 - at best it will be 1c differance - but that's enought of a reason for some
But for sub zero cooling all metal is a must
As for the kits - they must be the best on the market by some way.
With the exception of the fans (with it's braided cable and some googleing says it runs at 7v and 5v)
most custom loops would have that block, rad and pump anyway.
Nice you get both the intel and AMD brackets in the box.
Just get some mayhems bioside extreme and some distilled water locally and your sorted.
exactly that shadowscotland. I was really happy when these went live on the XSPC reseller portal.
they really are just high end stuff and the bits i would usually recommend to people anyway.
in honesty, it is almost pointless buying individual parts when a kit is this good. :p
I'm hoping more than expecting, but does the D5 Dual Bay Reservoir have any sort of vibration dampening?
I like the visability and accessability of a by res, but the XSPC DDC Dual Bay Reservoir I have at the minute vibrates and this seems to be magnified by the case :-(
Also, what's the limit for the D5 pump with regards to how many cpu/gpu blocks and radiators it can handle?
