Hi folks,
I've just finished up a HTPC that's both silent for movies yet still has the grunt to do gaming justice. Its also compact for such a powerful and silent machine.
I needed a fair bit of graphics processing power as I try to game at my 52" Samsung native res of 1920x1080 so have gone with dual ATI 3870 in crossfire. These cards are great because they're silent at idle ie. watching movies or desktop work. When gaming you can hear a faint hum from the fans but its still quieter than Antec P180 which is fully tricked out with acoustic treatment and 'quiet' 120mm fans. The 3Ghz E6850 CPU is entirely passively cooled using 8 heatpipes connected to the huge heatsink integrated into the case. The X38 based motherboard is also passively cooled. The noise from hard drives is a real problem when your dealing with a silent machine so the two 750Gb Samsung F1's are mounted in Xilence coolers and these are configured in a RAID 0 array.
PSU is a 620w Nesteq ASM semi passive model and is attached to the left case heatsink for additional cooling. I'm running a fairly power hungry setup and the fan never kicks in whilst on the desktop or watching movies. When gaming I can just hear it start up every few minutes for about 15 seconds, even so its still quieter than the Seasonic M12 I have in the Antec P180.
Everything is stock with no overclocking. CPU temps are 39c idle and 61c load after 40 minutes of folding. GFX hover around 60c idle and 85c load.
Overall extremely happy.
System spec is:
Case: mCubed HFX classic with Imon VFD and remote
Mobo: Gigabyte X38-DS5
CPU: Intel E6850 3Ghz
RAM: 4Gb OcUK DDR2 1066Mhz
HDD: 2x Samsung F1 750Mb 32Mb cache (raid0)
Optical: Pioneer Bluray
PSU: Nesteq 620w ASM Semi fanless
Graphics: 2x HIS 3870xt in crossfire
Monitor: 52" Samsung LE52M87
System spec is:
Thanks for the qudos.
