- 24 Oct 2010
hi guys,
i wonder if any of you can shed any light..
a few days ago i put together a new build system, the 1st time ive had an overclocked pc..
i got an Extreme-Krypton overclocked bundle.. this one!
..for the record..
CPU: Intel Core i7 950 3.06GHz @ 4.00GHz
MOBO: Gigabyte GA-X58-USB3 (Socket 1366) DDR3
RAM: Corsair XMS3 (3x2GB) DDR3 PC3-12800C9 1600MHz Triple Channel
..to this bundle i have added..
PSU: 750w cooler master GX
GFX: 2x Zotac 1gb Nvidia GTX 460's in SLi
MISC: Cooler master V8, 500gb sata, DVD-RW, Gigabyte clear case, win7 64pro.
i have the new system up and running and im happy with it's performance. i have the GTX 460's in SLi, and after abit of reading around, i learned how to overclock them. for these i have a stable overclock of 800mhz, and 1600/1950mhz for the memory and shader. overclock confirmed with GPU-Z.
with this configuration i ran 3D Mark Vantage, the benchmark was.. P28000, cpu- 45590, gfx- 24810.
the result of the 3D Mark Vantage benchmark is here, it also notes my system configuration.
now the question..
just after i had installed windows and was doing a re-start of the system, i got a strange message on the BIOS screen..something like this..
"the system has experieced boot failures because of overclocking or change of voltages. last settings may not coincide with current hardware state.
CPU clock 2936mhz"
im not sure it was exaltty 2936mhz, but it certainly didnt say 4000mhz!
also, note the 3D Mark Vantage result.. it says my processor clock is 2834mhz.
has my pre-configured overclock failed? how can i tell if my processor is indeed running at 4.0ghz as promised by the overclockers website?
thanks for reading..
cheers
..for the record..
now the question..
CPU clock 2936mhz"
cheers
If only OC had supplied the above info with my order it would have saved me a lot of stress!!!!!!!!!!!!!!!!!!!!!!!!!!!!
