Update 16:
Well its been a while!
I have got quite a lot of the 'little' bits done, mostly around taking the old rig to bits so that I can re-use some of the water-cooling gear.. got most of what I need now to complete the case and what I am going to call 'phase 1' and once that's done I am going to move onto phase 2!
So I have a load of pictures to take to show the progress, but I will start with the couple I have managed to take over the weekend... so lets start with the motherboard!
Full Cover Block:
I decided to go for a full cover block for the board... don't really need to as the NB and SB don't put out to much heat... but well I think they look nice! and give me a bit more room around the board to work with.. buy the time I have two 4870x2 on the board and all the water cooling pipe and that you don't really want a huge heatsink array all over it..
Overview:
Close Ups:
RAM:
Next job was fitting the water-cooling to the RAM, again not really needed but hey RAM coolers are really nice
So I got a couple of the new Aquacomputer Ramplex kits and they are really nice, good, solid and really quality
Looked excellent out of the box:
And nice to see some QC! (although I was a screw short!!, so can't be working that well...)
Any way will try and get some photo's taken this evening or tomorrow of the progress made on the case and the radiator arrays
