extreme oc settings for wc i7 930! help!
15 Nov 2008
hi all today i installed my water cooling in my first ever build consisting of:
sr-1 360 rad
sr-1 280 rad
swifttech vario d5 pump
xspc dual 5.25 bay res
ek supreme hf full nickel cpu block
ek 5870 v2 full cover block
temps are amazing now! gpu idles around 24 and maxes out in furmark at 36
the cpu is running a crude oc running 3.8ghz idles at 34 and maxes out under prime 95 at 60!
now i want some decent settings to push the cpu af far as possible hoping for around 4.4ghz!
hope someone can help!!!
Start off with the basics and see how it goes:
bclk:191
CPU Multi:22
Vcore 1.25v (set 1.3 in BIOS)
Memory multi x8
See how that goes.
It's helpfull if you give us your hardware spec (motherboard).
I have a very good clocking 920 d0 on a p6t deluxe v2, heres my bios settings for 4 ghz. You may need more vcore than me though. I use speed step and loadline calibration :)
I'll try to find my settings i used for 4.4ghz for you a bit later.
We have very similar loops, i have a single sr1-420 though :)
thanks jeffyb! i managed to find some settings for 4.2ghz last night and its running prime stable temps maxing out at 65!
would be very interested to see what settings you used for 4.4ghz but not sure weather i would need completely different settings with a 930
