Hello you may have read some of my previous threads, well eventually i go the pc i wanted the specs are as follows,
FX 4100 oc'd at 4.00ghz
Asus 6770 gpu
4gb of ddr3 hyperx kingston ram
Asus M5 a97 pro mobo
several hard drives totaling around 1.5tb
Anyway over time its been getting slower and slower to the point where this message is lagging as i type ? my mums laptop with a dual core is instantly opens google ect when you click on the mine take a good minute or two , i have run both avast and malbytes for malware and viruses and both remove any problems but still my pc is getting slower , what i have though is using and external Hard drive that i could go through each folder take what i want and know is safe then wipe all hard drives and re intall with a fresh win 7. would this work ? thanks
Asus 6770 gpu
