- 17 Apr 2010
Hello all, looking for suggestions on an Eyefinity 3 screen setup. I'm not really looking to spend more than £100 on each display, max.
Ideally each monitor would be in the region of 22", although happy to accept upwards of 19". Preferable resolution would be 1080p on each monitor, with the thinnest bezel, and response time possible for this price.
Will be gaming from a CF 7950 setup. I presume you still just use one cards ports though? (DVI-DVI, HDMI-DVI and DP-Active DVI?)
Many thanks,
Chris.
Many thanks,
Chris.
