Eyefinity cable question.
12 Jan 2010
Cornwall
Hey guys, had a Sapphire 5970 for a little while now, and decided I wanted to give Eyefinity a crack. Got 3 monitors and I'm aware of the basic setup needs etc. except with my GPU I only seemed to get a mini DisplayPort to DisplayPort adapter. I assume they would ship it with an adapter suited to my card, but I have no cable to connect it to my DVI slot on my PC monitor. What should I be looking to buy? Any help would be great.
You should have at least one monitor with DisplayPort for Eyefinity.
The "correct" setup is 3 monitors connected with DVI, DVI and DisplayPort.
I've seen some people using a DisplayPort to VGA adapter so they connect DVI to DVI, DVI to DVI and DisplayPort to VGA.
What connections do you have on your 3 monitors?
Depending on the card most don't come with a displayport adaptor and you will need to source that seperately.
You will need a active displayport to dvi cable for the 3rd monitor.
Sapphire do there own one more info here
I have mine running off Radeon 5670HD 1GB (another one in Crossfire) and the connections i have is HDMI, DVI and DisplayPort to DVI using the same adaptor listed above. Works great no problems.
