Is this video on only one monitor or on 3 monitors?
Clear advantage over other players![]()
I wonder if it would be possible to use eyefinity with a really widescreen HDTV so that you only had to have one screen instead of 3 but still have the benefits of seeing to the side?
Surprised its not banning players cos of the advantages of the this.
The resolution is impressive but I don't like the warping it creates.
I'm guessing that is because you're viewing the video on a normal monitor. Think about it, on a 3 screen eyefinity screen, the side monitors will be viewied from an angle and hence will have a sort of 'reverse warp'. Hence the warping you see in the video above will effectively cancel out and it should look normal ... in theory.
but shouldnt FOV scale linear with resolution anyway? otherwise it would distort the image onscreen i would think?
